Just collected my 1988 924S from the Porscheshop in Brimingham and what a fantastic transformation! They have replaced all the worn out old shock-absorbers with new Bilsteins and fitted uprated springs. The car now sits flat and is wonderful in corners - like it is on rails. This has solved the 'juddering' on hard braking and removed that vague feeling if you corner too fast - totally transforming the handling which I thought was ok before the work. I can't believe the difference.
Another thing I have had replaced was the throttle repsonse cam, again what a transformation. This changes the relationship between the pedal and the throttle, reduces travel, and makes it linear. The throttle bites straight away and is a vast improvement for so little money, it makes driving feel so much better. If you have a 924S or 944 I strongly recommend it.
I found the staff at the Porscheshop incredibly helpful and friendly and Ian gets 10 out of 10 for customer service- Nothing is too much trouble. This is a personal opinion and not advertising!
I have spent a great afternoon learning my car again with the new set up and even in the wet (and snow) is is vastly better. I think we sometimes forget that even the newest 924 is now 17 years old. Replacing key components with vastly improved modern versions can transform the handling and performance at least back to what it was when it left the factory if not better. Not cheap I admit but better than huge depreciation on some boring Eurobox.
Anyway thought I would share this with you and hope see you on 1st May at the frontrunner event.
Kind regards
John Stratford
Black 924S
Kind regards
John Stratford
Black 924S
