924s petrol tank
- Thread starter Guest
924nutter
marlin
They used a new product (At that time) but basically a wonder weld type stuff, you mix 2 types plastic together it becomes metal (Wallace and Gromit).
Any way worked a treat, no doubt lasted longer than the car and the cost no more than a good pub lunch. Sure there are even better products available now Space age and all that. GOT TO BE WORTH A TRY.[]
re: second point, the turbo was fine before the clutch went, I got Strasse to look at it, cos I just thought it would be slave cylinder or similar & the MOT was due, but they said it needed a new clutch & the brakes were shot. Decided not to spend money on it, especially running a second 924. I live in Leeds, more than happy for anyone to come & look at the turbo.
cheers.
marlin
ORIGINAL: craigybaby
just been to Halfords, they've got two products made by "Plastic Padding" called "chemical metal" or "leak fix" both sound good for fixing my petrol tank leak, do you think this is what was used on yours? It sounds dead easy to use, but for a novice like me, not so sure, but if its gonna save me £600+ gotta be worth a bash eh?
It was years ago they repaired my tank, but I am sure you will have to drain the tank of fuel and clean the area of leak back to bare metal.
Best of luck you do not have much to loose []
got the option of an 85 944 plastic tank or an 88 944 fibreglass tank. Mine is a steel tank. This is probably a stupid question but i'm used to asking them ! Is plastic the same as fibreglass? any ideas if either will be a perfect fit for my 87 S ?
cheers.
924nutter
its a series one, quite a nice example cosmetically.
Pity. The car in need is a series two and has different pistons, turbocharger and boost pressure.
