924S rear seat belts
vitesse
Our 924S MY 1986 does not have rear seat belts.Have obtained a complete set of leather seats to replace the "from new" fitted linen vinyl & cloth ones & the rear seat bolster has the holes next to the transmission tunnel for seat buckles.When I strip out the existing bolster,can I expect to find the seat belt anchorage points?
Cheers,
Colin.
I would think so yes.
I have a 1980 2.0 which has no holes for the seat belt buckles in the seats, but the anchor points are in the chassis - I would assume that they are standard across all models.
Alex,
Thanks for that;-I did suspect it would be the case & asking first is easier than crawling under the car.Next question then,Has anyone got a rear inertia seatbelt set in black they want to sell(undamaged of course)?
Cheers,
Colin A.
They will certainly be there. The mount for a three point belt can be found in the C pillar blanked with a large plastic cross-headed plug.
The mounting holes are only in place for lap belts but for proper inertia/retractable belts the rear mount in the boot area is missing a welded on bracket and will also require the later cars side carpet pieces fitting as well .
