944 S2 cab wheel compatability
- Thread starter anna m w
ORIGINAL: Big Dave UK
....944,s + 968 cabs are the same apart from the look...
And the engine, and the gear box, and the door handles, and the mirrors, and the door cards, and the cubby box, and the air bags, and......... the price. [
IIRC to get it exactly right you should use 7mm spacers at the front when using late 911 or Boxster wheels. Hands up how many of us do......that would be none then.
The wheels I have seen are genuine porsche wheels off a Boxter 1999.
Tyre sizes 17" 255/40/Zr 17 rear & 205 /50/Zr 17 front
Offset fronts 55 rears 50.
Will these fit! would I need spacers?if so would these be 7mm front back or both?
This is all new to me so many apologies for the dumb questions! But need to get it right.
Indi9xx
The offset will change with the wheel width in some cases, but as a rule wheels made for a model after 1987 will fit any model after 1987.
But you have to consider wheel widths.... for example, fitting a set of 10J 996 rear wheels onto the front of a boxster isnt ever going to be a good idea.
All the best
Jon Mitchell
