944S Idle Valve Location?
- Thread starter Guest
To remove the manifold isn't that difficult but it will mean removing the fuel rail and injectors, and the accelerator cable, dip stick and a LOAD of vacuum pipes. Not a difficult job at all but reassembley needs some concentration as it is all to easy to clamp vacuum hoses etc under the manifold and in the wrong place. It does help to mark which pipe goes where.
The manifold can be lifted out complete with the throttle body. At times it doesn't seem like it. It does take some wiggling tho.
Don't be tempted to stick a screw driver in the valve once you have it out. Some one tried that for what ever reason on mine and it had damaged the aluminium slider. This item costs up to £140 from an indipendent specialist, and makes a huge difference to the way the car runs at idle and at speed.
If you are going to remove the manifold, I would suggest replacing the vacuum hoses at the same time, as many of these run under the manifold to the front of the engine.
Have a look in the Garage Manual section of this site, it has tons of information.
Clarks garage
Diver944
ORIGINAL: Fen
Assuming it's the same as the S2 then it can be removed on its own (even by big-handed clumsy oafs like me). You need to remove a pipe to get it clear then it's not too difficult*
How the heck did you do that? I've often looked at mine and there's no way I could get my artistic piano playing hands in there [&:]
ORIGINAL: Diver944
ORIGINAL: Fen
I don't remember exactly but I know I did it. Maybe it's easier if you can put the roof down or something [8D]
