I'm hoping someone could kindly point out and help me with a few items.
Recently my 944S hasn't being running 100%. I believe I've found the culprit to be a very bad connection to one of the knock sensors (the connection was basically falling apart). Having taken the inlet manifold off I checked a few other items whilst I was there and found this:
The sensor on top is the Crank Positioning Sensor, but could someone please clarify what the sensor is at the bottom? I only ask because the wire running from it leads to the second picture and is obviously not plugged in anywhere. The only place where it looks like it could be plugged into is the plug below with a (what looks to be) OEM makeshift 'plug end' already in it?
My second question is to do with oil consumption. Having taken the manifold off I've found the inner wall to be covered in (what looks to be) a very viscous/gooey film of oil. Is this normal due to the age of the car and the way the oil/air separator and vacuum lines are plumbed in, or do you think there is an issue somewhere else? Possibly the seals on the oil/air separator are gone? My oil consumption isn't horrific (well within Porsche recommendations), but at the same time is still a cause of slight concern. There seems to be no oil leaks anywhere and no blue smoke at high-revs. Valve stems should be good too due to a semi-recent head rebuild...
Any help with either would be gratefully appreciated.
Many thanks.
Many thanks.
