944S2 clutch needed.
- Thread starter Big Dave
Diver944
I don't know if they will fit the S2, or if they are suitable. I do know (to the best of my knowledge) that my car is still on its original S2 clutch after 157k miles, so I think they are pretty good when standard.
sawood12
If you are talking about the turbo "Cup" cars, they have a more heavy duty disc with only 4 outer springs (actually these springs have another spring inside them) and don't have the inner row of 6 little springs. But it is still riveted as that is what I put in.
All these cars have the same pressure plate.
Better check to see if these discs will fit the S2 because as I recall the S2 has a 220mm diameter disc while I know the turbos have a 240mm.
Oh, and be careful about getting a puck disc for a street car as they are much more on/off in engagement and will chatter. Can be a PITA to drive on a street car.
ORIGINAL: IceShark
Mine is most definitely not for going down to the shops in, although Lindsey describe the clutch I bought as "streetable". We'll see, but I don't really expect it to be smooth, nor do I really care.
ORIGINAL: Fen
If you talked to Dave Lindsey, go over to Rennlist and do a thread search on his name and Spec clutches. Dave's idea of what is streetable is waaaaay different than most of the population. By ALOT.
Better like constant RPM matching when shifting. []
(January's edition of Purely Porsche GT magazine)
IMHO unless it has improved since the early days dont believe anything you read in purely poor GT
Tony
