944S2 Clutch pedal operation
rogero
anyone heard of this? my clutch pedal goes down overnight and only comes up to full working height after a few miles of running (but not pumping).
clutch works perfectly and bites at the right point and fluid level stays OK. One small sign of possible fluid leak on clutch hose.
however if you pull the pedal up (or hook your foot to pull up) to its correct position it stays there.
looking at a pic in manual there's only a master cylinder, pedal pivot and clutch power spring to check, all seem OK.
Any ideas?
Slave cylinder? Hidden behind the starter, but you will probably not see a leak there. That was the problem with mine.
