944S2 front brake hoses
- Thread starter peanut
pauljmcnulty
http://www.type911shop.co.uk/shop/article_326/944-1987-91-Front-Brake-Hose.html?sessid=xRcxXxwCh7K0nqFe55s8RCWuyCL2kh9fXQHozpbfTdZkpkwuH0wynRQL0VrjDwqD&shop_param=cid%3D105%26aid%3D326%26
Monkeythree
http://www.design911.co.uk/fu/pt66_...2-91/944S2-3-0L-1989-91/Brake-Hoses-Standard/
peanut
thanks Paul but that part number is coming up as a cam belt ?? 944 1987-91ORIGINAL: pauljmcnulty
Looks like the right one (I'm guessing you don't have M030). []
peanut
ORIGINAL: 944Scott
Why don't you put a set of braided hoses on, you can get a whole set of e bay for around £55
that would be good ....do you have a link or a suppliers name ?
ok this looks like the hoses you were referring to.
seems like they make them to order thanks for the tip
http://www.ebay.co.uk/itm/Wezmoto-B...arts_Vehicles_CarParts_SM&hash=item418a25bc37
pauljmcnulty
Type 911 do a braided set of four for £55 as well.
Chris, I think it's only the 250 turbo that's different? 220 turbo and S2 are the same. I'd give them a ring to check, though.
chrisg
If you can't find what you're looking for on eBay , either go direct to goodridge or take your old pipes to a local hydraulic hose supplier. It won't take them long I make you up a set.
Btw rear flexis are the same for all 944's
Chris
pauljmcnulty
Don't know the exchange rate but that must compare well with the UK indie dealers?
ORIGINAL: chrisg
.... take your old pipes to a local hydraulic hose supplier. It won't take them long I make you up a set.
Good idea, but I asked Pirtek about this last time I was in there and they said they won't do anything brake-related but were vague about the reasons (I suspect it's down to insurance and liability).
Other suppliers may be more relaxed about such things.
Rose Passion do the braided kit of all four for under 70 Euro inc. VAT.
As above
ChasR
Genuine Porsche hoses (I have had pattern ones fail on me within 2 years (admittedly on a certain car but two different cars all the same; generally with the ends fraying away, and then losing my brakes (and clutch seeing as that also the same fluid...)) unless you can be sure that the brand is good (both of my failures were from GSF).
The other and better choice would be to go braided. My preference here are HEL (their hoses are built with some of the best fixings IMHO which may for very easy fitting along with stainless unions) or Goodridge; I have used them over the years with alot of success and good results.
Whilst there are debates as to whether the braided items are suitable on the rear of a 944 they will be just fine on the front .
