944S2 front spring rates.??
Big Dave
HI folks
I wonder if any of you chaps know what the standard 944S2 front springs are rated at.??? ie lbs.??
OR where i can find the info easily...
From the workshop manual it seems those with purple dots are 23.8 N/mm and were use on standard S2's[FONT=verdana,geneva"] [FONT=verdana,geneva"]Another option is turquoise dots which were the same rate but 367mm uncompressed against 378mm for the purple ones.[FONT=verdana,geneva"] [FONT=verdana,geneva"]I'll leave someone else to convert N/mm to something less German in case I screw it up.[FONT=verdana,geneva"]
