Just to let others know how amazed I am at the improvement Redline oil has made to my 1991 944S2 gearbox.
Changing gear in this cold weather was becoming a problem until the oil warmed up. I had been using Swepco. But I decided to use 75/90NS Redline oil. the difference is huge. The change is much smooother even on cold mornings and the well known whine has reduced.
If you have these problem give it a try. You can get it from www.twincitymotorcycles.com.
