944T head bolts torque
buchos
Does anyone know how much to torque up the head bolts on a late 944 turbo?
The Haynes manual helpfully says, Head Bolt Torque: See chapter 6. Chapter six then says... tighten to the correct torque for your car!
Clark's Garage will be your friend here.
Look in 'Garage Shop Manual'. The sites a bit rubbish and it uses frames, so I cant link directly to the correct section: you need 'cylinder head'.
http://www.clarks-garage.com/
Simon
Cheers Guys :)
I see its done by angles not torque, I thought the 944 was a bit early for that, but easy enough :)
It depends on the model/studs I think. Id certainly have a root about for a factory manual (on t'internet) and confirm it against that too...
