944T
Lansdown
Can anybody give me an idea on what it would cost to change the oils seals on my 1990 944T? All of them aparently. I've been quoted £2.6k to include water pump and tappets which seems high but I dont have the experience to query the quote.[FONT=verdana,geneva"]
Brilliant! - do you want to look after my car for me?
[:D][:D]
Can you just replace them as you go? I had all the front ones done at the last belt change, where it's parts cost only pretty much, for instance.
Sounds a good idea. Will it damage the car if I drive it without replacing them immediately providing I keep the oil level up. The pressure is very good at the moment.
Can't see how, unless you either do a long enough drive to leak out too much oil or get a catastrophic leak like a 996/Boxster RMS total failure, which I've never heard of on a 944.
All 944s use oil, hence the reminder to "check oil" on the fuel filler flap. I'd want to replace anything that's worn or leaking at some point, as it's only adding a problem, but you need to weigh up the cost against the odd drip on the drive.
I agree with what is said, its practically free to do the rear seals when the clutch needs replacing and the front seals are similarly easy when doing the belts.
I've never known an oil leak on a 944 bad enough to cause a problem. Id focus on more important things like making sure the belts and rollers have been recently changed and if all is well. Enjoy until it needs something important and tidy up small jobs like seals in the area as you go.
its too easy to spend money for moneys sake on a 20 year old car. Better to take it to a garage who are familiar with working on the 944
I spent £500 fixing a cracked Cam cover which was leaking oil onto my exhaust causing clouds of white smoke
(The cost includes new belts and water pump whilst it was being done, although the belts were only a year/5k miles old)
