964
- Thread starter Guest
John H
ORIGINAL: RichardLW
Be very wary of that rust patch under the rear window. From what I gather, rusting here is possibly a sign of some serious problems which may well extend far beyond the bits you can see.
DUH, like what?
I have had cars with rust both at the front window seal and rear. No problem just get it done properly and ensure seals are replaced correctly.
Johannes
RichardLW
I'm not aware of rust under the rear window being that common on 964s without there being some underlying problem which may require attention. The front yes, but not the rear. I could be wrong though.
John H
From my observations of the market, the median value for a decent 964 seems to be about £15k to £16k. This is for good cars with average mileages and reasonable history in private sales. Expect to pay a bit more than this from the trade for the same cars, or quite a bit more for exceptional cars. Equally expect to pay a bit less than this for so so cars with patchy histories, lhd, or known issues.
However, don't assume that the asking price automatically equates to the condition of the car. All of these cars are now 12 to 15 years old, and almost any car you look at will need some catch -up maintenance work. Sure, you will read all the horror stories about oil leaks and flywheels, but don't ignore the more prosaic things too. Brake discs, pads, caliper-rebuilds, new tyres, worn shocks, suspension alignments, minor bodywork, trim repairs, etc, etc will very likely be needed on all but the most fastidiously prepared dealer cars, and it is very easy for this sort of stuff to eat up a couple of grand. Make sure you take this into account when assessing the car and what it's worth.
I speak with some authority, having just gone through this process myself, but I started on a private sale car at a price which made financial sense of doing this work. I have been horrified to look at several cars for sale in the trade at nearer the £20k mark which quite clearly needed all of the above, which would have made them a very costly purchase indeed.
By all means get an independant survey of a car, but even that is no substitute for a bit of experience, and keeping your eyes wide open.
Anyone care to comment?
John H
Good Luck
Pete[8D]
964 Tip(91) Guards Red
944S (87) Alpine White
John H
There is a small fan which blows air through the heater control, which is probably what you are hearing.
John H
Dave Wilkinson
The problem with the ignition switch is quite common and the solution is to fit a new switch. It doesn't need the key to be changed, just the electrical switch at the back of the key barrel.
I'm not sure how any metal from the starter would get to the gearbox. The automatic transmission fluid in the Tiptronic gearbox only requires 3 litres for a fluid change although 9 litres for a dry fill.
Hope that helps.
Dave
