Dave Wilkinson
Andres, The problem with the ignition switch is quite common and the solution is to fit a new switch. It doesn't need the key to be changed, just the electrical switch at the back of the key barrel. I'm not sure how any metal from the starter would get to the gearbox. The automatic transmission fluid in the Tiptronic gearbox only requires 3 litres for a fluid change although 9 litres for a dry fill. Hope that helps. Regards Dave
