964RS Engine overhauls
- Thread starter oldtimer
The 64RS engine does seem a lot more robust, only suffering from mist down changes ... ouch!
As said above maintenance is everything. Dont expect to open it up and spend a couple of grand doing the top end. Anticipate doing the works, then you might be pleasantly surprised. Whilst the Engine is a great engine, they are expensive to put right for the power you get out of them.
There are a few of us that have rebuilt engines on here and I'm sure we happy to share experiences with you.
Steve Brookes
Moderator
Hacki
ORIGINAL: h_____
If you are club racing one, I think many people go at least a couple of seasons and check with leak down or even dyno. As above really hard to tell otherwise. If you start missing gears or being messing on the downshift its going to be sooner. if the engine is in fine fettle leave alone, if it starts slipping (as per a leakdown), start saving......
Exactly. That´s what I remember from the club days, that is what people used to do.
A well maintenanced engine that has not been tortured by missed gears or early downshift (as said above) will last many seasons without rebuilt.
Rgds,
Hacki
Further to this, age means seals perish. Nothing lasts forever and the seals in our cars are getting on. Which means leaks are likely. A good tech will be able to advise on what you can and can't live with. You might decide leak free is the only way to go.
When I tore down the top end of my last RS (due to mis shift) at @ 35k miles (i think , it was a long time ago) the heads and valves/ guides showed very little wear as did everything else. Wisdom suggests that nothing lasts forever and I would suggest that any air cooled 911 is likely to show valve guide wear by 75k miles and track driven cars likely earlier. Nothing is set in stone and as the americans like to say, your mileage may vary.
