"964RS's are like buses" - it's official...
- Thread starter RSGulp
ORIGINAL: Rich Claridge
To quote Des in a telephone conversation at lunchtime today....
"964RS's are like buses - none for ages then three come along all at once." []
That was the case two years ago this is the biggest drought of reasonably priced 964RS I have ever known........stepped out of a drive in a 997C2S into the RS the other day........then I came alive......[
SimonExtreme
Come on Des. We are not Top Gear. Why should the 964RS be a "reasonably priced car"? With all that's going for it, they should be "reasuringly expensive"[ORIGINAL: carreraboy
..............................this is the biggest drought of reasonably priced 964RS I have ever known........
The 964RS will be going a lot longer than any new Porsche Kettle......
jason
They NEVER LEAK OIL! (Jason you should have spoken to me before Autofarm rebuilt your engine)
Presume this is me you mean.....mine certainly needed the work doing to it that was done...it had been previously fettled by ninemeister with some development work on the velocity ram intake system and had the intake stubs replaced with 993 units....lets just say I'm not entirely certain how well it worked[
Runs like a dream now though with many of the parts and leads replaced...looks like brand new too![
and as we all know I could afford to spend the money to ensure it was spot on it having been slightly on the cheap side in the first place[8|]
SimonExtreme
Is this another Des myth[ORIGINAL: carreraboy
My engine leaks oil. 3 different specialists have told me and they all agree where it's from. Although very small, I do have a slight leak from the crank front seal. In addition, I have a very slight leak gearbox leak from the front input shaft seal.
All the specialists agree that it isn't worth doing anything about either leak. They are so slight as to make no real difference but they are there. The engine itself is as good as it gets with the worst cylinder leak testing at 4% and good, proven power output.
What about the LSD? I thought it was extremely common for those to need rebuilding.Mechanics other than replaceables i.e Clutch, Rubber, Suspension never never nevr go wrong
ORIGINAL: SimonExtreme
They NEVER LEAK OIL! (Jason you should have spoken to me before Autofarm rebuilt your engine)]
993RS only Big problem.......
ORIGINAL: Yoda
Hi Simon. Not being funny but your is the first RS that I have heard of that leaks any oil. Most are dry as a bone. Agree that if the leak is small it isn't worth fixing staright away.
Yes very unusaul Simon, in fact the first I have known, don't think cos it's a RHD!
SimonExtreme
The car doesn't use any oil so the leak is very small. I have to admit that it could easily be specialists covering them,selves and that the oil marks are old and caused by something else.ORIGINAL: Yoda
WRT the LSD, Autofarm had rebuilt mine with new plates etc before I bought it and I was led to believe that this was needed more than most owners realised
B****x about the LSD first one I have heard of on a 964RS as the oil leaks.....
SimonExtreme
GT-One also diagnosed the oil leak. Their words, from their report are " Suspect slight engine oil leaks from crank front seal and running down back of engine". However, as mentioned, it seems that the car doesn't use any oil to speak of and I intend to do a full engine bay clean and we will see if the oil returns.ORIGINAL: carreraboy
It seems they are very good at oil leaks......[]
For what it's worth, everybody has advised against doing any work to the engine to correct the situation.
Yes even it's an any 911....................
I've had several done and when inspecting cars specifically check this. Cost to redo is similar to replacement clutch costs.
SimonExtreme
Regrettably, not. As Paul says, the car doesn't feel "wrong" when the LSD isn't wortking as the diff just works like a normal C2 one. It isn't something that is checked at service and most people (even machanics) would not feel the difference on normal roads.ORIGINAL: carreraboy
Thanks Paul that is certainly news to me, surely you would notice any defect while driving or should be checked picked up in a service?
I was keeping this one a bit quiet as it will make a big difference at Judgement Day with the type of corners we have! However, IMO, most cars with significant mileage will have worn LSD plates.
oceancarrera
Already making the excuses...[
