993RS idle ????
sambaman
i have a 993 RS cup spec , over the last day or so when sat on idle the car seems to be fluctuating from 1k going up to 2k sitting for a while then returning , any advice appreciated ....
thanks, keith
where is the valve on a 993RS ??? running no air filter , cup spec motor , not on the top as it is normally on vario ram engines !!
Hi samba man
Nice car,i know it well.You have the cup induction,one large throttle body.
The car will hunt up and down the revs until warmish,this is normal for a cup spec car and lumpy cams etc.It should settle down once warmed up a little.If you want to stop the hunting you would probably have to got to motec or similar,which is not needed realy
Live with it,it should be fine.
there car seems to have settled now for some strange reason , seems when it was very hot thats when the idle was not correct but its back to fine now , absolutely awesome car, looks lovely sat next to my 964RS !! what a picture ........Heaven !!!!
