sawood12
How do the two-part brake discs for the 993TT/993C4S work? When it comes to disc renewal time can you just get the disc part of the assembly thereby retaining the 'top hat' part? If so is there a significant cost saving and is the replacement of the disc a simple unbolting and bolting of the disc with no special tools or balancing procedures required?
I'm looking to upgrade my front brakes to the big blacks off the 928 GTS (same as big reds but black and alot cheaper) and in the kit i've been looking at there is the option of an alloy central top hat that uses the 993TT disc so you retain the alloy top hat part when you renew the discs. The advantage (apart from looking the dog's danglies as it can be anodised in any colour) is the whole disc assembly is lighter. I've looked in the 993 PET and can't seem to see the part numbers for the two component parts of that assemby. The 928 GTS disc is a one-piece casting, but the alloy top hat part of the kit is intended for the 944T so has the correct offsets.
Thanks.
Thanks.
