996T Clutch Replacement: OEM or Upgrade?
- Thread starter boggie
chriscoates81
They do.ORIGINAL: chriscoates81
I think sachs actually made the original clutch.
If you aren't going to put more power through it, not a lot to gain by fitting uprated clutch. If you are thinking of remapping, then it would be wise to upgrade to something like the GT2 pressure plate and friction plate.
boggie
Whilst I really like the thought of a lightened flywheel in addition to an uprated clutch but I have to keep costs down. Apart from having to get the expenditure past the other half, we have taken some serious hits in the last month with one car needing a new engine, the vintage Land Rover having an extensive pre-winter overhaul, a Tubi for the Porsche and three insurances / MOTs all converging in a perfect storm.
Porsche are quoting around £900 for a genuine clutch for our X50 which set me thinking about an upgrade...... Sachs 740NM perhaps?? I would want to keep the feel and operation as close to stock as standard. Any thoughts please?
DivineE
boggie
I have been recommended to fit the genuine GT2 clutch. This sounds a good plan to me, as it is a higher spec that the X50 turbo without any significant change in feel or operation. Does anyone know the torque differences between the X50 and GT2 clutches?
Cheers,
B
DivineE
ORIGINAL: AlexBell
If you have 600hp and the clutch is made for 450-500 then it's no wonder you damaged it..
No need for an upgrade if the power is stock.
The car was standard at the time. After my track day I noticed the car didn't want to go in and out of 1st/reverse or 6th properly.
Apparently I broke a 'finger' and so it wasn't clearing properly. It didn't have a problem with slipping even after I had it mapped but it's being replaced at the garage at the moment as a preventative measure (and because I've somehow been persuaded to upgrade to 600hp even though I was happy with 500hp)
DivineE
ORIGINAL: AlexBell
That road is long.... a friend of mine didn't give in until he reached 850.. []
To be fair 550-600hp is a good level, it's INSANE and yet people have still done 50k miles with regular track work on 600hp 996 turbos and had no problems with reliability. I always tune cars too far and then regret it! I will not be making that mistake again probably
