997Recal
- Thread starter kitchens
nottage
Or here is the text
"From a 997 owner
"I had a letter from my OPC waiting for me when I got home last night, this is the main text.
"Through regular quality inspections at Porsche AG, it has been identified that there is a possibility that the engine in your vehicle has been installed with the incorrectly machined crankcase. Due to a machining error, the intermediate shaft may not sit in the designed position in the crankcase.
To determine whether this fault exists in your vehicle, the engine must be checked and depending on the result, it may be necessary to install an additional spacer to the intermediate shaft bearing cover."
Any comments/additional info from 997 owners?
Rgds,
Kevin
Maybe they are able to identify specific cars where this issue applies, rather than the first 100 or so shipped since launch. I not sure how car manufacturers operate recalls, does anyone know?
dereksharpuk
Black80XSA
The same guy said when they do an RMS chnage they never fail again - four boxsters were raised on the ramps, three had rms failure. Only one 996 up on the ramps had rms failure, rest were dry
