Chris_in_the_UK
Well. I finally managed to get some diary space to do some of the jobs on the Cayman.
First up was the suspension and handbrake shoes. As usual this ended up being slightly more involved than firs thought!.
Car was put off the ground and all wheels removed.
First job was to strip the rear brake calipers off to get access to the discs and ultimately the handbrake assemblies. Gotta be careful with those PCCB rotors!.
Once everything was safely off it was time to have a bit of a clean up before the new shoes went in. I used a product called Alubright to clean the hubs and associated alloy parts - it is very good, but you MUST protect the finished parts once you have scrubbed and rinsed them. For this I used Jet Laq which seems to be just the thing as it does not leave a greasy residue.
This shot is taken during the cleaning.
All nice and clean and the new Pagid handbrake shoes installed on the offside.
Took most of the day with at the cleaning and associated work found along the way.
Next up is the third radiator installation - I will post pictures along the way.
