I always wonder exactly what various "100 point safety check"s really include... It occurred to me a while ago just how many bulbs there are on a 944 - I got up to fifty... well, 49 actually - I deliberately missed one out for you all to try and think of.*
No, I'm not seriously suggesting some of these aren't important, or that some of them are important... just a bit of fun really... although I may just use it to check all are working on my cars (including No. 50, which I know works on at least one of them)
1 Headlight, dipped, Near Side
2 Headlight, dipped, Off side
3 Headlight, Main Beam Near Side
4 Headlight, Main Beam Off Side
5 Front Side Light, Near Side
6 Front Side Light, Off Side
7 Rear Side Light, Near Side
8 Rear Side Light, Off Side
9 Brake Light, Near Side
10 Brake Light, Off Side
11 Indicator, Front, Near Side
12 Indicator, Front, Off Side
13 Indicator, Rear, Near Side
14 Indicator, Rear, Off Side
15 Side Repeater, Near Side
16 Side Repeater, Off Side
17 Rear Fog Light, Near Side
18 Rear Fog Light, Off Side
19 Front Fog Light, Near Side
20 Front Fog Light, Off Side
21 Front Driving Light, Near Side
22 Front Driving Light, Off Side
23 Reversing Light, Near Side
24 Reversing Light, Off Side
25 Hazard Lights
26 Courtesy Light - Over Windscreen
27 Courtesy Light - Boot
28 Glovebox Light
29 Clock Bulb.
30 Cigarette Lighter
31 Vent - Central Air/Demister Slider
32 Heater Fan switch
33 Main Defrost button
34 Heater slider controls (left?)
35 Heater slider controls (right?)
36 Hazard light switch - position
37 Hazard light switch - in use
38 Rear Demister - position
39 Rear demister - on
40 Headlight switch
41 Main instrument panel - left
42 Main instrument panel - middle
43 Main instrument panel - right
44 Front fog-light switch - on
45 Rear fog-light switch - on
46 Alarm working or otherwise light - Central locking switch
47 LH door pin
48 RH door pin
49 Ashtray illumination.
50 - Yes there is one![]
I really must get out more...
* OK... At the time I could only think of 49, I have just thought of another one... and then, I dare say, someone will think of No. 51, 52, 53...
Just to complete it:
50 Under bonnet light
51 Air conditioning - position
52 Air conditioning - on
53 Main "Warning" light
54 Brake fluid low level
55 ABS warning
56 Low brake pads
57 Sidelights
58 Main beam
59 Low fuel
60 Low oil pressure
61 The early dash cars had a "Change up now" light...
And further...
62 Front fog light switch - position
63 Rear fog light switch - position
64 Rear Numberplate light - left
65 Rear Numberplate light - right
66 Indicator/Hazard warning repeater
67 Seatbelt warning
68 High water temperature warning
69 Fuse test light
25 Hazard Lights
28 Glovebox Light
29 Clock Bulb.
40 Headlight switch
47 LH door pin
48 RH door pin
55 ABS warning
56 Low brake pads
57 Sidelights
58 Main beam
59 Low fuel
60 Low oil pressure
And further...
67 Seatbelt warning
69 Fuse test light
