A few jobs to do.....
Contraband
Just a few advisories then!! I look forward to seeing pictures of your progress. I have so far found the car to be easy enough to work on... They are rather well engineered.... [;)]
Indeed! TBH the advisories were the front suspension top mounts, lower radiator hoses and the clutch slave cylinder hose - the rest is my 'associated' list!!!.
ORIGINAL: Contraband Just a few advisories then!! I look forward to seeing pictures of your progress. I have so far found the car to be easy enough to work on... They are rather well engineered.... [;)]
After my major service there were a couple of 'advisories', I have decided to do these and a couple of other associated stuff at the same time.
In no particular order:-
Replace front top suspension mounts.
Replace front anti roll bar bushes.
Replace all brake flex hoses.
Fit RS engine mounts
Fit new gearbox mount.
Replace front radiator hoses (supply and return).
Fit GT3 brake master cylinder.
Fit RSS underdrive pulley.
Fit K&N air filter.
Some of the bits ready to fit.....
I will post a few threads/pictures etc. as I go along.
