A good honest indie in bucks ?
hello
does any1 know a good indie garage, honest that knows about 944's ? I need to do a compression test and other things.
IN buckinghamshire, slough amersham etc .
thanks in advance.
pjb
I've not used ProMax for servicing but they've done other work that I've been very pleased with too.
For other options a little further south I would also suggest considering JZ Machtec who are good if a little pricey.
However I currently use http://www.rpmtechnik.com/ at Cheddington and would recommend them unreservedly, great value and faultless service.
Best regards,
Peter
You won't go wrong with any of those three, I've also used all of them over the years and been happy. JZ are the priciest but probably closest to you if you are in South Bucks
hello all,
thanks for the help indeed.
( but I cant get over the fact rpm almost charge double for a clutch than other specialists... that's quite a difference...)
pjb
I'd love to know which Porsche Specialists you keep referring to as a quick trawl of the well known and reputable websites reveals the following for a 2.5 Lux clutch change as a menu price including VAT:
JZ Machtech £1136
RPM £908
Hartech £810
These all state they use a genuine clutch which may well cost a little more than an OEM part
Remember that a clutch change takes around 10 hours labour and an OEM part itself is about £350
