Given the regularity with which I seem to destroy brake ducts, I thought I might try 993 air deflectors. These atach to the A-arm and deflect air towards the brake, rather than ducting it right in, so they are not as effective but they should be good enough. Given my last track days have been without any ducts at all and I have survived just fine, these should do the trick.
You can mount them the quick and dirty way I did with zip ties or weld tabs to your a-arm and bolt them on like a 993.
The part number is 993.341.083/4 (L/R) and they are cheap.
To zip tie them you need to drill a series of holes. 10 seemed a good number.
![82720380FE314038B0E6CE26DFEF63D5.jpg](https://www.porscheclubgb.com/forum/legacymedia/upfiles/388/82720380FE314038B0E6CE26DFEF63D5.jpg)
