Benjs
Hi all
I decided to get a few months of ownership in (and the nightmare of changing pads and discs) before asking a bunch of questions of those that know. But as i'm sure is inevitable i made my list at lunchtime of 'things to do'.
To my surprise the list isn't that long, it however could be properly expensive so as i'm making sure i keep it serviced at least once a year, even with low mileage, so i want to ask a bit of advise before blowing any spare pennies.
First off is on exhausts. After a bit of investigation i have found i have PSE (code XLF under bonnet) but with no switch. Unfortunately the great news ends there as on inspection the bottom seams of the boxes are quite rusty and the nearside is blowing. SVP have said they will look at them when they do the service in November but if they can't be saved i want to know what the options are. New PSE is out of the question as i believe they are £1500 + vat each, but could i find used or should i just go aftermarket stainless (i can't believe i my ownership lifetime that the genuine PSE will add much to the resale).
Second up is Stereo. Mine has PCM1(non most) with Bose and cd changer. The previous owner had an Alpine CDE173BT head unit with bluetooth fitted (albeit the mic just lies on top of the steering binnacle) and the Nav and cd disconnected. Now having tried various experiments with stand alone nav unit (which interferes with the radio) i think i'll have to go for a double din unit and have the PCM taken out. I really didn't want this but the only other option is a dension set up which won't have bluetooth or DAB. My question is, which units are recommended and when changed will i loose all the BC information on the dash (not much more than temp and mpg and range i know but still useful)
Last (i promise) Is there any place someone can recommend near Worcester for detailing. The paintwork is pretty good but in strong sunlight it shows a lot of swirls and i'd like them removed.
Thanks all for reading. I'm hoping to get along to some meets etc soon and get to see some of the other fantastic cars i see on here
Cheers Ben
Cheers Ben
