A Punt That Paid Off
robwright
OK my power windows have been next on my hit list for the car. My driver's side has always been slow and sounds like a food mixer and the passenger stopped altogether. I stripped out the passenger, opened up the motor and lubed it up as well as the regulator, put it back in and it worked a dream. No such luck with the driver's side. Obviously had a much harsher life. Did some searching and came up with well let's say he is a man that does window regualtors. I guess you could say he is a window reglator *** Too good to be true I thought at just £87 with motor but seemed legit and came with a year's guarantee. It arrived today anyway and first surprise it was a Lucas part. Second surprise it fitted and worked like a dream. As good as new. Only slight snag was the new one came with oblong plastic sliders to fit into the top rails. These proved almost impossible to fit or at least both together. I subsitituted them for the black wheels that came off the original regulator, spliced in the cable to the old loom and Robert was your Father's brother.
You should add this part to the interchangeable parts list on this forum.
When I was looking for a regulator I ended up with a used one (with motor) from an '83 944. Exact fitment to my '91 S2 however the cast frame that the motor bolts to was a bit lighter than the '91 casting. While I didn't need a motor I did find that Mercedes (and a couple of others) used the same motor available for about half what Porsche wants for one. IFIRC about c$330 for a regulator, about C$300 for a motor and if you are unlucky enough to lose a window about C$500 for the window with the guide bar glued on it - the guide bar is NOT available separately).
