Hi, I'm new to the 911 world (just over 3 weeks) and am loving the car (C2) [
]. However, there is something that I'm considering asking the OPC about but was hoping for some input from the forum: what is norrmal for the clutch pedal travel.? I seem to have to depress the pedal all the way to the floor to start the car, and gear shifts can be clunky unless I do the same when driving. This makes gear changes a little slow. Maybe I'm just getting used to the car, but I'd appreciate any feedback before I ask the OPC. Thanks in advance.
A query on clutch travel
- Thread starter edgiee
My former C2S was the same, Keith. Certainly fully depressed to start. I think I used to get away with less than full travel on quick changes with perfect timing - yeah right, in my dreams then![
] Give it few more weeks, maybe, to see what it's like when you know the car better?
Your seat position should be based around the distance of your hands to the steering wheel, not the clutch. Ideally when seated and your arms are at full stretch your wrists should be level with the top of the steering wheel rim. This is so that when turning the wheel for a bend, your opposite shoulder isn't forced away from the seat bolsters, giving you less lateral support.
Again reference the handbook (having a pdf version can make for anorak like behaviour):
Seat Adjustment
Warning!
The seat may move unexpectedly if you
attempt to adjust while driving. This could
cause sudden loss of control or personal injury.
f
Do not adjust seats while the vehicle is in motion.
The backrest locks must be engaged at all
times while the vehicle is in motion.
Safety belts only offer protection when the
backrest is upright and the belts are properly
positioned on the body.
Improperly positioned safety belts or safety
belts worn by passengers in an excessively
reclined position can cause serious personal
injury in an accident.
f
Do not operate the car with the driver or
passenger backrests excessively reclined
(see "Seat position").
In the cabriolet, the windstop may be
damaged during seat adjustment and when
folding back the front-seat backrest.
f
Adjust seat so that the seat backrest does not
touch the windstop.
Seat position
An ergonomically correct sitting position is
important for safe and fatigue-free driving.
We recommend the following procedure for adjusting
the driver's seat to suit individual
requirements:
1. Vehicles with manual transmission:
Adjust the seat until, with the clutch pedal fully
depressed, your leg remains at a slight angle.
Vehicles with Tiptronic S:
Adjust the seat until, with your left foot on the
footrest, your left leg remains at a slight angle.
2. Rest your outstretched arm on the steering
wheel.
Set the backrest angle and the steering-wheel
position so that your wrist rests on the outer
rim of the steering wheel. At the same time,
the shoulders must still be in noticeable
contact with the backrest.
3. Adjust the seat height to give yourself enough
headroom and a good overview of the vehicle.
4. Electrically adjustable seat:
Adjust the seat angle until your thighs rest
lightly on the seat cushion.
Manually adjustable
comfort seat/sports seat
A Seat height
f
Use lever A in a pumping movement:
Upwards "" seat moves upwards
Downwards "" seat moves downwards
B Fore and aft
f
Raise locking lever B.
Move seat to desired position and release
lever.
Ensure that the seat engages correctly.
C Backrest angle
f
Operate switch C until the desired backrest
angle is reached.Totally agree, Rodney, but if the steering wheel fore and aft position is not adjusted correctly either you may not be able to get full clutch travel. Long arms/short legs etc. It certainly took me a little while to get everything positioned just so. For me the way to do it was to adjust seat to get clutch travel correct and then adjust steering wheel position fore/aft/up/down to get wrists on top of wheel etc. But I'm sure there are other methods........[
PS Edit I was typing this while Allan posted the handbook excerpt - honest[
ORIGINAL: tscaptain
Totally agree, Rodney, but if the steering wheel fore and aft position is not adjusted correctly either you may not be able to get full clutch travel. Long arms/short legs etc. It certainly took me a little while to get everything positioned just so. For me the way to do it was to adjust seat to get clutch travel correct and then adjust steering wheel position fore/aft/up/down to get wrists on top of wheel etc. But I'm sure there are other methods........[]
PS Edit I was typing this while Allan posted the handbook excerpt - honest[]
Absolutely.
Thanks for all the posts. Really appreciated. Regards seat position, I'm 29" inside leg and longish arms (I tell my wife - if I was 32" inside leg I'd be 5' 11" [8D] and she says if my arms were shorter I'd be 5'5" [
]), so it probably needs more work to find the ideal seat/steering wheel position.
