A question about Supersport brakes
- Thread starter 38F3E1
Front calipers - 930 351 091/2 03
Front discs - 930 351 047/8 02
Done a bit more research and I see for 1985 and 1986 the car was officially the '3.2 Turbo Look' model and it was only in 1987 with the introduction of the G50 gearbox that it became the 3.2 Super Sport (aka SSE). Both got the full turbo running gear. Prior to 1985 you could order a 3.2 with a turbo body as an option code (but it didn't get all the turbo bits with it).
Managed to find a complete 2nd hand brake, hubs, banana arms set off a car which I would like to use on my early car project hence the interest and the question. Just need to work out if it's off the 85/86 version and therefore will have correct banana arms for the 915 gearbox or if its off the later cars which may be different because of the G50 gearbox.
Ian.
dixhuit
ORIGINAL: Nick Moss
All 3.2s with the M491 "Turbo Look" had full Turbo running gear.
Except they didnt have the Turbo tie rods ! (well what did you expect for a £10,000 option)
Nick I have been busy but will give you a ring to get to your man on import numbers
Simon
with the normal calipers
Thought it was to do with incorrect caliper pistons being fitted during a brake overhaul, not the wrong calipers??
PM me for price if interested [
Mike
