A spacer too far ?
- Thread starter ChrisW
Hacki
the Cup car has 21 mm spacers and 9,5 rear and that is as far as you can go reasonably..... but offset is 68 mm! I think the 9" RS rim has only 55mm offset, so get your calculator. I think, it´s indeed a step to far by a few millimeters.
mm is a measurement we use on the continent! For you it´s probably about 1/16th inch, 3 shillings and 1/2 an ounce to wide... or a half pint? Let me have a few pints and I´ll tell you...or not, having then lost the ability to speak.[]
All the best,
Hacki
ORIGINAL: Melv
No spacers will work with pink wheels....[&:]
But the 'oink in the pic is very discrete ...
I think they will work, but you may need a gnat's todger more negative camber ..........
Jamie
pncarrerars
Hacki
ORIGINAL: jason
i've got 18's on my 9's chris...not sure I'd go any further!
That sounds like the limit to me, too. And no two shells are the same, so it might just work on one car, but it doesn´t on the other. Quality limits are from 1992.
Rgds
Hacki
pncarrerars
Pete
ORIGINAL: pncarrerars
Just double checked. My spacers are 23mm (not 21mm as stated in previous post) with standard 9" mag wheels. No rubbing problems.
Pete
Many thanks !
If you look at the tyre width at the point adjacent to the narrow black trim line, it's wider on the Toyo than on the road tyre.
And at the top, it also looks to fill the arch a little less ....
