A year of 944 turbo ownership!
mushtykev
.........I have only covered 160 miles!!
Due to the problem i experienced in this post .....http://www.porscheclubgbforum.com/tm.asp?m=755259&mpage=1&key=
It did turn out to be the head gasket, but upon removing the head i noticed scoring in no2 cylinder due to the fact the spark plug had broken & dropped debris into the bore so i have the following done:
New liner for no2 cylinder-cylinders 1,3 & 4 were honed
New Goetze piston rings
Head skimmed,new valve stem seals & valves lapped
New sachs clutch & pressure plate
Flywheel lightened (not excessively) & balanced with crank
New wildfire head gasket kit
New camblet & balance belt with all rollers & tensioners
New Genuine water pump,thermostat & turbo thermostat
Injectors serviced & pressure tested
New genuine oil pressure sender
New genuine exhaust gaskets for complete system
Vacuum hoses replaced with samco silicone hoses
Every o-ring & gasket for oil feed/return pipes all genuine again
I am sure i have forgotten loads...but car is in for mot tomorrow so fingers crossed will be back on the road hitting the twisties around Cornwall by the weekend :)
Oh also had passenger side inner,intermediate and outer sill replaced & bottom of front wing done as was starting to bubble, drivers side will be done next month. Will add some pics soon for anyone interested :)
https://www.facebook.com/photo.php?fbid=10200497249868332&l=9181425cbc
https://www.facebook.com/photo.php?fbid=10200497249508323&l=daddb412b2
https://www.facebook.com/photo.php?fbid=10200497263428671&l=9f3d83716c
https://www.facebook.com/photo.php?fbid=10200497269828831&l=80f480ad09
https://www.facebook.com/photo.php?fbid=10200497268868807&l=d038730a52
https://www.facebook.com/photo.php?fbid=10200497270388845&l=326f556e22
https://www.facebook.com/photo.php?fbid=10200497270548849&l=821b7bbd0a
https://www.facebook.com/photo.php?fbid=10200538977911507&l=f9f7d385fe
Hopefully them links work, if not i will upload the pics to photo shack or something.
Wow,some big work,engine looks lovely,hope she pays you back with years of fun,looked after these cars will last a lifetime.
Enjoy[:)]
ORIGINAL: mushtykev
photo.php
photo.php
photo.php
photo.php
photo.php
photo.php
photo.php
photo.php
Added some '
' for you
Nice to see you back and all rebuilt Mushty. A freshly rebuilt engine feels lovely and you'll really appreciate that BOOOOST! [:)]
