Aaawwww! My nuts!!
adrian996
Does anyone know if there is a socket available which has some sort of inner 'soft' layer which won't chew up my nuts when I use it to take my wheels off? Cheers!
You could try an impact driver socket. These are formed in a soft material to avoid shatter and are dull blue/black in colour. Wrap electrical tape around the outside to save wheel finish.
Hope this helps.
Regards,
Clive
Try PORSCH-APART - details in PP. I got one from them years ago that worked well with the black wheels nuts which I had at the time. About £25 I think - expensive but well worth it.
do a search on ebay for wheel nut socket , you'll find loads of different kinds starting at about £10 if i remember right.with various inserts etc to protect the nuts.
Most Porsche accessory suppliers such as Porscheshop, Design911, Type911 et al sell a "softsocket" for your nuts which is a 24mm deep socket lined with a nylon or soft aluminium insert.
Word of caution when buying new tyres.... The mouth breathing nut jocket saunters over, relieves you of your soft socket, snicks it onto his air wrench and whips off your nuts. He will later hand you back your socket with a completely mangled insert.
Ask me how I know[:mad:][:mad:][:mad:]
I always insist that they use a torque wrench rather than an air thingy in order to avoid bald nuts.
