ABS and brake recommendations
- Thread starter Mike IRL
Did you see this thread? http://www.porscheclubgbforum.com/tm.asp?m=392661&mpage=1񠢿
Mike IRL
Yes, I spotted that link too but I thought the focus was mainly on pricing rather than a broader discussion on what people have used good or bad. I was hoping to open that debate a little.
If the wear indicators are removed carefully they can be re-used, but definitely fit new dampening pads. It's up to you wether you change the caliper bolts, but have a couple of spares handy. If they haven't been fitted with anti-seize compound they can be a bu**er to loosen. The workshop manual says to change them, but most people don't bother. HTH.
watlina
AFAIK they are all German made
http://www.sebro.eu/homeengl.html
http://www.otto-zimmermann.de/index.php5?Itemid=136
http://www.ate.de/generator/www/com/en/ate/ate/general/home/index_en.html
If thinking of upgrading the brakes it's not cheap. The Porsche option is usually to just go bigger but I believe if you want to move to GT3 or Turbo brakes on the front you'd also have to change the uprights and that would be expensive.
The other option is to go with something like a set-up from the US firm http://www.performancefriction.com. I thought long and hard about this as you can get a set of front 2-piece discs with their Carbon Ceramic pads plus Carbon Ceramic pads for the rear (for use with standard discs) for similar money too what you'd pay Porsche to fit a full standard set.
Part Box in the UK sell them
http://www.part-box.com/index.php?cPath=968_1058_1069
It would work out at about £880 inc 15% VAT for the Performance Friction parts + on top for a complete new set-up you'd need new rear discs and all the shims and bolts for front and rear so about another £200 making £1100 total in parts.
For me it just wasn't worth twice the money when the standard brakes are pretty good for road use. If you do a lot of track days then the Performance Friction set-up would really pay off as they should last much better and when the disc needs replacing you can just buy the disc and not the center to save a bit. But for me if the standard brakes aren't good enough on the road then it's probably because I'm going too hard in the first place [
watlina
That's Marque 21 based in Dorset. I bought all my shims and pads from them and would of had my rear discs from them but they hadn't got them in stock at the time. Their prices were good and they were friendly and helpful on the telephone when sorting out which bits I needed. I used them on recomendation from other members.
Last time I checked the prices were the same if bought via eBay or their web site.
