ABS FAILURE SYMPTOMS
- Thread starter tiskev
If it does there is probably a fault & associated warning light.
The ABS should cut-in before the tyre starts sliding & then it will release the pressure on the relevant wheel(s) & re-apply it again very quickly - maybe giving you a pulsing / juddering feeling at the brake pedal while it is working (dependant on ABS system). The juddering is not the tyre, it is the pump in the ABS system.
Dependant on how hard you push the brake pedal the system may be operating on anything between just 1 upto all of the tyres - eg on a 911 you often only get 1 or both front tyres trying to lock up because there is so little weight on the front. You have to push very hard to cause the rears to try to lock up - unless its very greasy / icy.
For the Cayenne, I would imagine the weight distribution is very equal, but the brakes will be biassed to wards the front - so front tyres are most likely to lock first, but dependant on road surface, any could lock up.
Paul
2004 996 C2 40th Anniversary
