Kongsodoken
started the engine []
so got a running car almost No boost, No power steering, no brakes
so added the brake fluid and bled the system ......got a perfect firm pedal first go....chuffed[]
but the ABS light is still on, does not go out after engine start,
got brake lights, grounds are good, going to bridge out the relay tomorrow, then replace the relays on the pump, Anything else I should try? Any tips welcomed
I'm out of my comfort zone if it don't work first time[]
