abs light
alberto
i have asked the boys on tipec, who have been really helpful, but could do with a few more opinions. i have checked the ohms at the sensors the off side are at 1000 ohms at still and then up to 1500 when you turn the wheel. the nearsides are about 850 ohms still and 1200 when you spin the wheel.
when i put the igniion on, he abs light comes on (as it should) then when i start the engine it goes out (as it should) then 30-40 seconds later it lights up? has anyone had the same experience and if so how did you sort it?
Broken wires are also quite common. There a plugs on the front inner wings where you can also check the resistance.
Tony
