ABS not working
- Thread starter Dekker
Neil Haughey
BTW can't say what it would be like on a 964 but on my S2 when the ABS had completely failed a few years back the car was almost undriveable, anything more than a prod on the peddle would cause all 4 wheels to lock on solid.
Steve Brookes
Moderator
Dekker
will do regards cleaning the connections.
I'm just surprised that no indication of failure. I did alot of research before posting and read articles about how the system works and the checks that it does to verify that it's working. Yet it isn't.
See you w/e after next.
Steve Brookes
Moderator
Steve Brookes
Moderator
Dekker
ORIGINAL: Steve Brookes
Any progress David? Mine's completely stopped working now too! Had to do an emergency stop recently - never seen so much tyre smoke!! []
No change. I took a rear wheel off to bleed the brakes and found nipple seized so I've decided to rebuild the rear calipers and do it then. I've read a lot about the systems and will overhaul and check everything this winter when not used so much.
Let me/us know how you get on fixing it.
appletonn
All to no avail in my case, as it turned out to be the main ABS relay in the luggage compartment - try swapping that for one known to work fine and see what happens. Although, I did have the warning light and initial warning buzzer on mine when first driving off from start up, which you don't mention?
I also removed and cleaned up each of the wheel sensors, that screw into the hubs to align with the toothed rings inside.
Good luck!
Steve Brookes
Moderator
Steve Brookes
Moderator
ORIGINAL: VITESSE
What bit of the above quote do you need explaining
The bit about how you can draw a conclusion that having to do an emergency stop to avoid a dozy, impatient driver that did an overtake that was not viable, is bad driving on my part? I'll stand by my praise for the 964 brakes that even without ABS working, played a significant part in preventing that driver ploughing into my front end or worse, taking out the innocent cyclist.
The ecu upon ignition/starting does a brief check of power supplies/earths and resistance of the various components in the abs system and then a quick run of the abs pump and if that all checks out it's all systems go as far as the warning light is concerned ,in the next few meters at approx 5mph the ecu makes sure that the speed sensors are generating approximately the A/C wavefroms that it is programmed to expect under those conditions. If those conditions are not met the the warning light will illuminate and turn off the whole system reverting the driver back to conventional braking.
for instance : If the fault code wheel speed sensor left hand rear implausible signal is present, The ecu doesn't know if that is the sensor itself, the wiring between the sensor and the ecu,the ecu faulty itself , or the ring fallen off the driveshaft!! All it knows is that the data from that sensor is outside the range that it's programmed to expect. only the area of the fault can be taken for granted.
Best of luck with the fault, Cj
Steve Brookes
Moderator
Steve Brookes
Moderator
If anyone else needs theirs looking at I'd suggest they contact them because the Bosch tester is the only way to isolate what the problem is and they're as rare as hen's teeth.
totyfinalist
And We have the bosch tester (c2 turbo/rs models) here in our workshop.located in wiltshire
Steve Brookes
Moderator
ORIGINAL: K90
Steve are you currently writing the supplementary volume to Adrian's book?
No mate, thanks for the compliment but my knowledge only scratches the surface when compared to folks like Mr Streather and Dave Wilkinson.
Dekker
ORIGINAL: totyfinalist
do not forget that only the 2wheel drive models require the bosch abs tester, 4wd ones use the porsche system tester one or two or piwis plus durametric and a few others!
Can you explain what piwis plus durametric is all about?
totyfinalist
The first three being made for Porsche,(porsche system tester) pst1 (bosch kts300 hardware/porsche software), pst2(bosch kts500 hardware/porsche software) and piwis tester1(bosch kts650 hardware/porsche software) and the recently released piwis tester 2(panasonic toughbook/laptop based with siemens interface), durametric is an American aftermarket program and hardware to carry out basically the same job as the dealer tools ,without the price tag and at a somewhat more basic level in some cases on certain systems depending on the model in question.
Ok .
