Hi all, I've had an ongoing ABS problem which leaves the ABS light warning light on. Not only is it annoying but very soon it'll be an MOT failure! It's made all the worse by the fact that there are a lot of posts about this but none that really describe my car.
It started at 10 mph (which suggested a sensor problem). Now however, the lights come on on tick over (after about 10 seconds) even before the car moves!
Last weekend I plugged up a multimeter to each sensor (+ve and -ve in each respective female socket on the output from the sensor) and tested the resistance as I turned the wheel. Each one showed a change in reading which I assume (I'm no electrician!!) means they are all working. The next thing I tried was to change the ecu with a spare I have; still the same. Next I changed the relay so I bought a second hand one which I am assured works... still the same.
Given that the light comes on before the car even moves and that each shows a resistance change I have ruled out the sensors. Right before the problem started I could hear the pump priming so for now have ruled this out too (this is also hopeful thinking!!). Given that the lights come on when the car is on tick over I guess it's an electronic problem and perhaps there is a short or a ground on a circuit somewhere. My next move is to whip the driver side wheel inner arch out and clean up the earth connector by the pump. If this doesn't work I might try another ecu just to completely rule this out as its the next cheapest thing!
Any other suggestions (not including black tape over the warning lights, removing the bulbs on the warning lights, removing the relay all together!!!! Sensible ideas please!! ) would be much appreciated. [
Are there any diagnostics available for S2 ABS systems?!
Thanks as ever!
Thanks as ever!
