Anyone know how to remove this plastic cover to get at these relays?
Following on from the other thread on my ABS/ABD my Durametric cable tells me I have two ABS faults (front left sensor and "valve relay"). According to a post on Renlist corrosion on contacts of the relays is a common problem and so is finding the secret trick to opening the cover to get at the relays!
Above picture is looking at the relay box (which is opposite side of spare wheel from battery). Spare wheel removed to take photo.
Anyone on here know how to open the box? It looks like it probably slides upwards but it will not budge and I can't see any latches or tabs. The actual controller box (to the left of the photo) slides upward easily.
