mwadams
Okay here it is ........
Washed the car Saturday, start the car up and the ABS warning light comes on, drive the car and it goes off after approx 2500 rpm.......... switch the engine off and restart and no warning light.
Left at work all day, come out and fire the car up and the warning light is back but again goes out when the car is driven as above.......
Checked the rennlist tech forum and one suggestion was look for moisture around the brake fluid cap and contacts.... none there.
Someone has suggested that dry joints in the PCB of the clock can cause the fault ?
I suppose the only choice is a visit to my local specialist, or do I need not worry as the light goes out when the car is driven ?
Mark
Mark
