ABS warning light
- Thread starter 944turboS
ORIGINAL: 944turboS
Anyone help me out here. Took the car out of hibernation last week & on startup I do not hear the ABS system go through its system check & the warning light is lit in the dash. [&:]
Get it checked over, could be a number of things. The ABS system really just consists of an ECU controller, a pump and sensors. Sounds like its either the pump or the ECU. Doesnt mean they are knackered could just be a fuse or relay. If its the pump then a new one is about £1600, second hand between £400-£600 ECU is about £900 new and £300 second hand. Get someone who know what they are doing to do the diagnostic stuff, i didnt and it ended up costing me £1000 to get it sorted.
Any who needs ABS, if i was to do it all again i wouldnt bother.
eastendr
ORIGINAL: slim_boy_fat
Faulty ABS = no MOT .....
Surely you can remove ABS if you want to? After all it still (to my knowledge) isn't a legal requirement on new cars and it certainly wasn't when 944's were new. I have wondered about taking it off the Turbo although I'm not sure it would benefit in any way. If it comes up u/s when the car is back together I might explore the possibility though.
eastendr
We used to fit a switch in line with the brake fluid level sensor. If the ABS computer thinks the brake fluid level is low, it will go into bypass mode. ABS is normally enabled, when you get to the track and want to disable it, just flick the switch.
HTH
eastendr
Direct quote from Slim
ABS is NOT tested for an MOT.
QED...
See above. I suggest you consult an MOT testing station ..... and your insurance ..... I'm pretty sure that disabling ABS on the road would count as a modification ....
Having a shunt where ABS was obviously not working (traffic division are very clued up on that ...) would make for an interesting claim subsequent to investigation.
Anyway it's all hypothetical since I'm the only one talking about removing it and I'm not seriously considering actually doing it.
ORIGINAL: Fen
Absolutely it's a mod and you'd have to declare it, that was what I said. My point is that it shouldn't be an illegal mod like removing your seatbelts would be.
Yes Fen stop getting Rick upset.. lolsss
ORIGINAL: 944turboS
Interestingly the car came out of hibernation straight to the MOT testing station & passed.
danmason
What should this sound like? I've never heard it (yes, I have working ABS!)
ORIGINAL: Fen
A kind of groan/whirr as you pass 6mph for the first time when you start up.
Pretty much described yourself there Fen [
