I wondered if any other owners have experienced quite severe wear on the inner tread of their tyres. I do appreciate that our cars have negative camber but I have noticed recently that the wear is excessive ie. Across the rear (19' wheels) it is almost bald in the inside and 4mm on the outside. Is this normal or do I need my car set up? I would really appreciate your views.
Acceptable tyre wear
- Thread starter Arran
Not sure if you have 986 or 987 Boxster. My 986 used to wear fronts bald on inside when about 4mm on outside, even when geometry perfect. This was typical for model, but rears wore pretty evenly. 987 Cayman wears fronts and rears evenly, but not sure if this is also typical of 987 Boxster. Someone else will no doubt comment.
