Access to ECU / relay board
- Thread starter steveoz32
steveoz32
Both covers are bolted together in the middle. The hardest part is getting those damn rubber washers back around the covering plates.
If you are experiencing starting issues and want to see if the ignition relay is working, bypass it, it's the black one. To test, bridge MFIDI relay in position 1 on the relay board (black), remove relay with ignition off. Use fused wire or pin to bridge position 80+87 on the relay. Turn ignition on to test.
Serial of relay is 14195253B.
