carlmthompson
Busy installing my Boost Controller, but I'm having (typically) problems.
Firstly, instruction number one states that I loosen the Banjo (done that bit) and disconnect the pipe by losening the jubilee clip - err but I can't, it's a crimp finish.
Also, the tubing is a different diameter to the one supplied, so even if i could get it off, it wouldn't fit on the outlet side of the controller (too big). And if I used the supplied tubing, it wouldn't fit on the other end where the original larger pipe comes from the banjo.
Anybody else had this problem? Anyone got a solution other than using some wierd air-line connectors I have?
Is there a different type of Banjo, and would it be easier getting one of those and a new length of pipe?
