Sandspider
Hi all.
I recently did my first oil change, and I went from 10W40 semi synthetic to 5W40 fully synth. With the old stuff, oil consumption was very low, maybe a litre every 5,000 miles. But with the new stuff, either it's burning it a lot quicker, or it's leaking out somewhere. (I wouldn't have thought it would leak more when running as the viscousity would be the same at operating temp, and I can't see any oil on the road or my drive).
In any case, I checked the oil level tonight after a 30 mile drive, and according to the dipstick the oil level is below minimum. (It was at max about 500 miles ago). But the oil level warning light isn't on in the car, nor is the oil pressure light (assuming they work of course! Oil pressure light definitely comes on when ignition is first turned on). Oil pressure is normal (5 bar under acceleration, about 4 bar at warm idle) and there are no odd noises from the engine, so is it possible that my dipstick is just inaccurate? I fail to see how it could be, but I also fail to see how everything else could be normal if oil level is really that low.
Many thanks for any thoughts / suggestions, and I will check oil level again when the car has stood for an hour or so.
Giles
Giles
