adjustable shocks?
- Thread starter cococola
There are a number of brands, with different parameters being adjustable. The most important one is the rebound adjustment, which most (including the Koni option) do.
Worth it? Very subjective. In my experience, most people fit them with one setting set and never change it. So the ability to adjust them is a bit of a waste of time. Also you need to take the Koni's off the car to adjust them, so it's quite a hassle even if you want to. I have the Koni's on my car and they are very good, and were cheap when I bought them. I did actually change the settings once I had fitted them - from medium to firm - and it improved the rear end handling noticeably, at the expense of ride comfort.
You pays your money etc ...
sawood12
ORIGINAL: ghost
I've been considering the SPAX kit. They also have adjustable ride height - which might be fun. I'd like to lower the car, but if I don't like it I can take it back to std.
Not as easy as it sounds i'm afraid - especially with the rear suspension due to torsion bar springs, and even then as you lower the car you will change camber and toe settings which are not so easy to adjust without the proper gear.
ghost
ORIGINAL: sawood12
ORIGINAL: ghost
Didn't think of that. Thanks for the warning.
wardtimothy
http://cgi.ebay.co.uk/porsche-924-944-koni-adjustable-rear-shocks-/220667086320?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3360c885f0
944 man
Presuming that the dampers you choose allow you to alter the bump, rebound and preload settings to a worthwhile degree, you still have to be able to set the b*stard things up! I found it difficult enough setting up one fully adjustable damper on the back of a bike (there were hundreds or permutations) and the problem doubles, at least, with a car.....
Of course: Id still buy them... [
CarreraRSR
sawood12
sawood12
