As above really, I have the POrsche manual on disk but its a bit confusing, the pictures are not too clear.
Mine has a sway bar, I think I recognicse the huge 38 mill eccentric for ride heig adjustment, but where do i measure it from and to? The manual suggests fromt he centre of the torque tube bolt to the centre of the wheel, but then it says to measure it from the contact surface of the road or something?
The the camber and toe. Where does the manual show which the camber ecentric bolt is, also it says to loosen the spring plates to radius arm bolts? Are these the same bolts to loosen for the ride hight too?
It mentions the slotted groves in the spring plate for toe adjustment, and mentions a special tools to do it? Which bolts are the ones to adjust the toe?
The diagrams are really poor IMO in the manual, i am sure once I have it all apart it may make more sense, but just in case, any help out there!?
cheers
cheers
