Adjusting throttle pedal angle ?
- Thread starter TTM
The pedal has a stop under it to limit its final point of depression
Loosen off the adjuster on the throttle cable at the throttle body - so you don't bend anything.
Wind down the pedal stop untill the depressed pedal is where you want it. Then adjust the cable tensioner untill full throttle matches the fully depressed pedal. Job jobbed!
