advice for changing window motor
- Thread starter MRGT
pauljmcnulty
Elliot
I find that the motors dont go and people assume they have.
I would think that the main cog on the reguator has corroded. Easily rectified if you remove the 10mm bolts secure the window and squeeze the regulator out of the lower hole in the door.
Soak it thoroughly in WD40 and then petrol. Remove the gearing unit (2 10mm and a screw). Try rotating the cog on this unit. If stiff this is a cause. With grips keep rotating this until free and then grease the inner and wd40 the cog.
now look at the mechanism. If you put pressure on it it will open and if good will close straight away. If not spring is weak and you will need a new one.
Good luck
